S280 shelter removal from m35a2 without a lift, any ideas?
22/45
47
Indianapolis IN
I have a pretty good idea in my head, involving a winch to pull the shelter and a come along in the bed of the truck to control the rate of speed it exits the bed. I'd use two vehicle ramps to let it slide out of the back, then once it's on the ground I could put dollies under it and wheel it around as needed. Anyone done this before? If so, did you do it differently?
I have a truck that needs the shelter removed so it can be sold but we don't want to pay a local tow truck company to remove it due to the costs involved.
I've seen the threads of the self lifting frames people have made to take these shelters on and off. Good idea and worth persuing if the shelter was ever going back on.
19,166
Quick look shows some versions of the S280 at about 1600# so my question is are your ramps heavy enough? Should you "block up" the middle of the ramps to support the "weight in the middle?
I'm spoiled rotten having a crane here... I would hate to have your ramps collapse with the shelter about half way off the truck.
22/45
47
Indianapolis IN
Yes, we would use cribbing in the middle to keep it from bowing.
I also spaced that I have a loading dock at my disposal. Without checking measurements I believe the m35a2 bed is about the same height as a dock. Dragging it that way would be a lot less trouble and less margin for error it seems.
19,166
Yes Sir!
A dock would be a wonderful way to do that job!
