Safety (inspections)
dmetalmiki
2,026
London England
It has come to our attention recently when servicing 2 1/2 and 5 ton trucks for colleagues who are not familliar with or will not service their trucks properly (or at all) that when the wheels and drums are pulled to see whats what on more than two occasions now we found the rivets LOOSE and the brake linings sloppy on their shoes. This could be a major failure with dangerouse consequences if they pulled (or sheared) off when driving or braking. This is just one more additional pointer to look out for when stripping cleaning and (then) adjusting brakes. ON A PERIODIC BASIS.
Rifleman
HOT Arizona
These shoes your talking about with the lose rivits, were they a factory OEM part, or were they a replacement aftermarket part? If they were an OEM part can you list the cage or manufacturer number stamped into them.
RAYZER
58
sanford/florida
This happened to me, I had excessive squealing noise coming from the front wheels (on my deuce) when braking, pulled one side apart to find everything looked new, pulled the other side and noticed that at least half the shoe rivets were missing like they were never installed and the rest were loose.
This truck was fresh from the government and had no maintenance performed untill this.
The brake shoes were white in color instead of the standard red.
