Savagleable, or a boat anchor?
rhurey
14
Bothell, WA
So, took a chance on a 80 gallon tank to hook to my MEP-803 for an aux tank.
Got it home and pulled the covers off of one port and looked inside...
So my first thought was to not even bother unloading it. But I'm still kinda new to this, so this something that can be saved, or off for scrap?
JRM
12
Brightwood, Oregon
I have a 275 gallon home heating oil tank that's way worse. I use a cim-tek 2 micron filter that removes everything larger than a virus. I even use the fuel pumped from that in my HPFP picky rigs
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Diesel is just thin oil. See if there is a radiator shop that will dip it in caustic solution to clean up and use it! Once you put fuel in, there will be little rusting. A good filter is a good idea too, make sure you have a shut off so you can change filters without dumping a bunch of fuel.
I have seen way worse.
Artisan
227
CDA Idaho
A handheld glass bead blaster will make quick work of all that
if you can get to it. A few hours, some labor, a vacuum and
some diesel approved paint and your good to go.
rhurey
14
Bothell, WA
Well, huh. Learning.
The opening at the top is 6x6 and tank is ~22x24x45H so I'm not sure how much access I'll get to the bottom. But it's in the garage and I'll start to beat on it real soon like.
Fuel filter and perhaps a pump to stir it is now on the list. Thanks guys.
