Score: Tree stump (1), mule (0)
bigmike
354
Dixon CA.
update: tear down complete, ready for rebuild
Taking the front body tube was tricky. You remove all the bolts but the tube won't come out. if you remove the start button and the block where the lower basket bolt threads in, the tube can slide towards the drivers side and get clear of the axle housing
the remaining parts weren't that bad.
here are picks including what the inside of the drop housing looks like.
saddamsnightmare
80
Abilene, Texas
March 25th, 2010.
BigMike:
I always heard that Army Mules were prone to biting their drivers, this one seems to have bitten you in your back pocket.......;-)! Now I know why Unimogs are designed to go where the mules can't.... As I had one try to follow me up a East Texas sand pile, and he got nowhere near where the Unimog went due to the stiff suspension....
I hope yours gets ack on its feet, uh, wheels, soon and you install that special CIA stump locating radar on her right thereafter.... At east no one but the wallet got hurt...
Cheers,
Kyle F. McGrogan:lol:
bigmike
354
Dixon CA.
struggling with a bearing race
Bill Watson said this could be chipped out with a cold chisel. I've been chippen' but it don't chip. Any other suggestions????
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
I'm guessing you are trying to remove the needle bearing? Think what he is saying is use the chisel to cut the needle bearing to remove it.
stumps
12
Maryland
I've had some luck on needle bearings that are in blind holes, by filling the bearing up fully with grease, and hammering a shaft into the bearing hole. The shaft acts as a piston, and the grease drives the bearing out of the hole.
-Chuck
1,178
ditto to stumps, wear saftey glasses and a dirty shirt!
bigmike
354
Dixon CA.
-Chuck
Well, the cold chisel didn't do it but a die grinder did. I was super careful to just cut thru the bearing race.
There is an axle seal down inside as well. be careful not to hit the housing...like it didaua
bigmike
354
Dixon CA.
Update
OK,
I got that $%#@ needle bearing out and the axle seal. Lucky for me the new seal was rubber encapsolated so it sealed the damage I did to the housing trying to get the other out.
I cleaned re-assembled the drop housing the the axle housing today. It slid together very nicely. I gave her a coat of paint and she'll be ready to re-stall next weekend.
powerhouseduece
Pasadena, Md
-Chuck
That makes a huge freaking mess! instead of using grease, get a huge handfull of toilet paper (clean, unused!), soak in water for a few seconds, then pack the wet paper in the hole and use a punch to pack it in. The paper will hold in the water and will push the bearing out. All the mess you have is a little water.
bigmike
354
Dixon CA.
update: No longer a three legged mule!!!
Got her all back together.
I installed the new housing and drop gear assembly. No issues there. I slid in the small body tube and gaskets. You may need to pry the two apart with a screw driver to walk the gasket in.
The long body tube was a different story. It's too tight to get back in there without dropping the gas tank. I soaked the hardware for 3 days with PB blaster. I don't like the philips head screws (they can strip easily). So, I dropped the tank about an inch and slid it sideways just enough to allow the body tube to slide in parallel. This is the only way it's gonna go in there.
After that, it was re-tighten everything, add a bit of gear oil and away we went.
She runs just fine and less leaks now then before the crash:razz:
