TexAndy
- 15
- 38
- Bee County, Texas
Any of ya'll tried taking the top off a 6TL to scrub bad sulfation off the plates?
The guy at Interstate gave me a tip. Hold the battery about a foot off the ground and drop it. That knocks the sulfation off the plates. He showed me on a battery that was junk and shorted the first time, he did the drop test and re checked, no more short and when he put it on the charger, it looked like it was gonna take a charge!
You probably broke the plates, but you can see if they'll take a charge. It's worth a try to see if you can salvage an otherwise junk battery, but I wouldn't try it with a battery in service.
I'd recommend buying a desulfating battery charger. They're not that much more expensive than a normal one and it is the right way to do it. Then install a solargizer on the truck and it will prevent the sulfate buildup in the first place.
Later,
Joe
