Sealing washer pump grommet
rcamacho
914
Bainbridge Island Wa
Leaking well enough to wash my feet and floormats. I have not been able to locate a replacement sans the whole pump assembly. 3M body sealant did not work. Silicone it or what
All ears.
Yeah, it rains a lot in WA...
Coug
4,670
Olympia/WA
I like the Lexel or Dap clear sealant. They make a good seal, even to wet surfaces, and unlike silicone they can be peeled off.
I used it all around my windshield as well, both inside and out.
rcamacho
914
Tried DAP Ultra Clear today and had no luck with it sticking to the body or grommet. I suspect it was too cold at 40ish to apply or may be expired
REF
133
Porterville Calif
Funny thing is I pulled mine apart several times sealed it with multiple types of sealant finally to find that it was really leaking from the output barb. Replaced the small spring clamp (hose clamp) with a small rip tie problem solved. couldn't see the forest for the trees.
rcamacho
914
Yeah I’ve been going through multiple leaks during rains here. In this case I’ve got a leak around the outside diameter of the rubber grommet and also through the wires feeding through the middle of the grommet. I’m gonna try sealing both with polyurethane sealant later on.
papakb
1,196
San Jose, Ca
If you go to your local auto parts store and ask for "windshield sealant" you get a slightly less viscous version of RTV that flows more easily. That will allow it to get down into areas you might not be able to apply regular silicon sealant to. I use it for sealing up connectors that I don't want to leak.
