74M35A2
- 339
- 83
- Livonia, MI
Mods, are you putting 5 ton (M939) mod threads in the new M939 folder as well? I guess this thread is not necessarily a mod thread since it is factory parts, but more of a question going forward.
Hi all, hope you and your families are staying healthy.
I can't seem to find the TM which illustrates the add on cab items for when the LWS turret ring is installed. I'm all set for the LWS itself. I have the more robust front cab mounts, but I also have some turnbuckle type links which go diagonal across the lower door opening (?), as well as there is some cab reinforcement plate? Guessing that goes inside along the back bottom of the cab? Maybe these turnbuckle links connect to it? Have seen a pic of this plate on another SS thread, but not installed, no part numbers, or installation pics or TM info.
If anybody has any TM reference guidance, part numbers, diagrams, or actual pics of these cab reinforcement components alone or as installed, it would be greatly appreciated.
Thanks.
Thanks.
