Seems like transmission is slipping when cold
LMTV89
27
13
Virginia
Im not sure if this is a temp issue but recently since it's gotten into the 40's here when I first start the truck after a 5 min warmup the transmission is slipping and barely moves the truck, going from N to 7 or R there is very weak engagement, engine tone doesnt change much. Putting it mode and 1 doesnt change anything either so it seems like the converter or tcase is not transfering power. If I leave it idling for just another 5 minutes I'll get a very positive engagement and truck drives without issue. Anyone even seen that before? Fluid (15w40) is clear and full.
Video
GeneralDisorder
4,306
Portland, OR
Check the filters? Perhaps the fluid is too thick when cold and not flowing through clogged, collapsed, or damaged filter elements?
I would get the 15w40 out of it and put in Dexron ATF. The military stopped using 15w40 in the FMTV's and the ATF shifts better.
Skyhawk13205
212
Alaska
Video
Can you put into mode and check that range and select 1st gear. My guess are low pressure to your clutches caused by fluid restrictions. Allison recommends preheat for 15w-40 at 5deg F. You could also have a brake that are releasing slowly because of ice.
