spicergear
- 26
- 0
- Millerstown, PA
The spacers and bolts came with the kit when I got my Selectros a couple of years ago. They would not otherwise be able to be mounted.
You can put a double splined axle and a locking hub on the front tandem and run with 1 rear axle only. I don't know of any 5 ton locking hubs, so you would have to pull an axle shaft out to run with one rear axle only. The deuce and 5 ton originally had sprag transfer cases, so they were always in 6x6. If the rear wheels started slipping, the front axle drive automatically engaged. On the later trucks with airshift transfer cases (deuce only) you were always in 4x6, if you flip the switch you are in 6x6. The later 5 tonners had a modification to the air system on the transfer cases to use an airshift switch to turn the truck from 6x6 to 4x6 for highway use.pa.rich said:I have a question about putting hubs on these trucks. On a duece or a five tonner, Is it possible to put the hubs on a front axle AND a rear axle and just drive with one rear axle pushing? Will they fit on?Another question about these hubs: On the older civilian 4WD trucks the manuals said not to use four wheel drive when the hubs are disengaged. They didnt want the axles turning at that time. Whats the difference with these larger trucks?Is the five ton in only rear wheel drive when in high range ? Or are they always in 6X6 either range. On the civie trucks you have a choice of high range 2 wd or high and low 4wd. Can anyone fill me in on this?
Ouch! I was going to order a set from them, but after tax and handling the price was right at $540, almost $100 more than the other place. Plus, they are out of stock.OD_Coyote said:I just ordered a set from Summit.
That is correct. The hubs are designed to handle the rotation, so they hold up fine. When you use one on a rear axle with a double splined shaft, there is practically no rotational difference speed between the axle shaft and the hub, as the wheels keep everything turning.spicergear said:Touching back on what pa.rich wrote...and someone can smite me if this sounds too far out too lunch but wouldn't you think the hubs being used as they're designed so that the hubs spin as the axle (front) remains motionless when the front isn't engaged. That means that the guts of the hub are constantly absorbing the rotation from the hub and lockout to the dormant axle. Now, if the truck was in 6x6 mode and the front axle was engaged wouldn't there be less rotational difference between the hub/lockout and axleshaft as now the axleshaft would be rotating at nearly same speed as the because the driveline is all moving and the wheels are all rotating.![]()
I guess I'll suck it up and order Ouversons from Hot Rod Deuce.
Because there is now a Summit location in McDonough.They charge sales tak in Ga, that was almost $40.
The best I could find is $595.- plus shipping for the Ouversons. Anyone knowing a better source?rmgill said:Why not buy the Oeverson hubs for that price?
