Semi-catastrophic Rockwell Failure ? Anyone ever seen this?
Floridianson
2,512
Interlachen Fl.
[QUOTE=welldigger If you miss a fine metal shaving or 2 who cares.
See you don't have OCD going on. Sometimes you feel like a nut sometimes you don't. Back to my Meds.
rivercreek
Berryville, VA
Update: Acquired a complete rear differential assembly from TacticalTruck (Jeff) over the weekend. I cut the axles and removed the rear driveshaft to make the truck drivable for the short-term. With the weather as it is forecasted here in this area I am not going to tear into the bad rear under the truck at this point. Once I've got a few days with no threat of snow, i'll pull it out and take a closer look. Undecided at this point whether it will be best to replace entire unit or just clean pumpkin/tubes and replace third member. Thanks for all the input and advice everyone. Except Zout. :)
