OK, I've got the pyro and boost gauges in and need to setup the lighting for the instruments. I have a 24 to 12v converter to use for the pyro power and for an accessory outlet. I want the instrument lights to work with the master lighting switch !
So, I understand that I need to wire the two gauges in series. Just to make sure I understand:
I'm going to tap off of one of the instrument back lights for power so that the lights will work with the master switch. So, I take the single wire and run it to the positive connector on one gauge and the negative on the other gauge. Then on the first gauge I run a wire from the negative over to the positive on the second gauge and then to ground.
Is this correct ?
Thanks, an electrically challenged Deuce lover![Smile :smile: :smile:](https://www.steelsoldiers.com/images/smilies/icon_smile.gif)
Is this correct ?
