Series instrument light wiring, how to ?
rrrr
Missouri
OK, I've got the pyro and boost gauges in and need to setup the lighting for the instruments. I have a 24 to 12v converter to use for the pyro power and for an accessory outlet. I want the instrument lights to work with the master lighting switch !
So, I understand that I need to wire the two gauges in series. Just to make sure I understand:
I'm going to tap off of one of the instrument back lights for power so that the lights will work with the master switch. So, I take the single wire and run it to the positive connector on one gauge and the negative on the other gauge. Then on the first gauge I run a wire from the negative over to the positive on the second gauge and then to ground.
Is this correct ?
Thanks, an electrically challenged Deuce lover :smile:
m16ty
228
Dickson,TN
No. You will run the 24v to the "+" on the first light. You will run the "-" from the first light to the positive on the second. You will run the "-" on the second light to ground.
This is how my pyro and boost gauge lights are wired.
m16ty
228
Dickson,TN
If one bulb burns out it breaks the circuit and they both go out. I guess you could call that bad but nothing a new bulb can't fix.
