Serpentine belt tensioner out of adjustment?
Autonomy_Lost
1,541
Pennsylvania
I looked in the TM's and googled the issue but couldnt find an answer.
My M1151a1 was received from govplanet with the alternator not fully bolted in. I'm trying to add the last bolt, but the problem is that I cant get enough slack out of the belt to move it into position. Is there some other adjustment point besides the belt tentioner to get more slack? Or do I just have the wrong size belt?
Mogman
10,144
Papalote, TX
Take the belt off.
Autonomy_Lost
1,541
Pennsylvania
Then put it back on after securing the alternator.
I should clarify, I was able to pop the belt off one of the idler pulleys and create enough slack to secure the alternator. But now I can't get the belt back on, its as if its too short. The tentioner is completely maxed out.
I did some more googling, and it looks like there may be 2 variations of this belt in slightly different lengths, but I'm not sure. I sent an email to MAC Motors to see if they can help.
Mogman
10,144
Papalote, TX
It makes a big difference how and what pulley you try to get the belt back on to, it is likely the correct belt.
Autonomy_Lost
1,541
Pennsylvania
Mogman
10,144
Papalote, TX
2" would be a HUGE difference in belts, it is tight, not for everyone ;)
It has a number yes???
Autonomy_Lost
1,541
Pennsylvania
Also my truck came from Yermo with a note on it that said "no belt," but it did come with a belt. I wonder if they just threw whatever they could find on there and unbolted the alternator to make it fit.
Mogman
10,144
Papalote, TX
In this world anything is possible, it does have a number yes?
Maxjeep1
1,920
Las Vegas Nevada
This belt came from Mac Motors. I bought it for a M1123 with numbers above 199,000 or whatever it is. Is this what you got? The belt in the background is cogged. The one I got from Mac was not B496671F-6E6A-4601-83C1-B78F8474D368.jpeg
Autonomy_Lost
1,541
Pennsylvania
I'll look for a number, that should have been the first thing I did. But yes its "cogged" with cross hatch looking pattern.
Currently trying to get multiple small children to sleep so I'll check tomorrow.
Autonomy_Lost
1,541
Pennsylvania
As you can see, even after bypassing an idler pulley its still tight as a banjo string. This is with the alternator fully bolted in, and the tensioner barely has any travel left.
I dont see any markings on the belt but I havent fully removed it to check the whole thing yet.
Autonomy_Lost
1,541
Pennsylvania
I think you have the belt on wrong possibly. I think it goes underneath the 2nd pulley. You need to get it away from the radiator hoseView attachment 876592View attachment 876593
Yes its on wrong because its not long enough to go on right. It was underneath of that idler pulley before I had the alternator fully bolted in. Dont worry I'm not running the engine this way.
