Shear Pins do Work!
Mackfire68
ENOLA, PA
Does anybody know if all SHEAR PINS are the same? I broke one and put a bolt in temporarily. Can I use a SHEAR PIN for a snowblower or one from a farm supply store or are they special militay pins?
m16ty
228
Dickson,TN
They are made from 2024 aluminum. Heat treatment unknown but I'm on a mission to find out.
You won't find them at the local farm supply.
BFR
Rocket Surgeon
2,330
42
North Georgia
My 1955 edition of the ORD 9 lists the part number for the pin as G742-7368685 with no manufacturer part number, but it states that G742-7368685 supersedes G742-7538740.
G742-7538740 is listed and crossed with the following manufacturer part numbers…
GW-304505
RC-1328N2
SD-914781
Does any one have a newer ORD 9 to compare to?
Can any one use these to find the NSN?
Edit, found a NSN (I think)
5315-00-736-8685
1,193
Snow blower shear pins are typically a 1/4" grade 2 bolt. That is not sufficient , for the m35A2 winch shear pin.
BFR
Rocket Surgeon
2,330
42
North Georgia
item name
pin,straight,headless
first end style
1 chamfered
hole arrangement style
2 both ends drilled
first hole diameter
0.078 inches nominal
second hole diameter
distance from centerline of hole to end of pin
0.094 inches nominal
center to center distance between holes
2.187 inches nominal
pin overall length
2.375 inches nominal
pin overall diameter
0.2810 inches nominal
first end taper length
0.031 inches nominal
second end relationship with first end
identical
first end taper angle
45.0 degrees nominal
material
aluminum alloy overall
