kurtkds
- -1
- 18
- Puyallup, WA
I've asked this question before but.. When shifting from neutral to Reverse I can hear the cylinder clunk and the puff of air. Shifting from reverse to neutral same thing. This sounds normal, now when shifting from neutral to forward I hear nothing, same with going from First to Neutral, nothing. I have heard that the forward sprag could be disabled to prevent the truck from getting "really stuck" and reverse was left alone so that the truck could be backed out..I think the air shift transfer case in an M800 series is solid as it. The shift mechanism from forward to reverse is a very simple well thought out design. To see if it works, start truck, build air, shut truck down, move shifter from any forward gear to reverse. You should notice a nice pffft of air and a nice solid clunk. If you're not hearing both, you have some work on your hands. With the M818 in my yard, I oiled the "sprag shifter" via the airlines and still have a problem. I took the transmission tunnel sheet metal off and noticed somebody had plugged the vent line on the transmission poppet valves. Removed the bolt, Transfer Case pffting and clunking as it should and no further issues with this truck.
Any truth to this?
