Shift seal
Ang2gna
Maine
Never mind. I think that is for the transmission. Does anyone know the Napa, etc part number and tool I can get to replace the transfer case shift shaft seal?
Retiredwarhorses
4,603
Brentwood, Calif
It's actually an O/ring held in by a nylon retainer....no, you don't have to remove the tcase to replace it.
its a 5min job....you just need to clean up the area, remove the lever. You will need something point and sharp to pry the retainer out.once that's out you will need to dig the oring out....you will need to look in the TM for the part numbers.
Ang2gna
Maine
Great! Thanks for the help. I'll post photos to help others when I get to it.
Ang2gna
Maine
Is there any trick to keep the yolk from spinning so I can take the nut off? This is for the input seal. Thanks.
