Trying to rubber gasket that goes under the shifter plate. Are these available or do you have to diy
https://www.ebay.com/itm/311209487060?hash=item487587ead4:g:Tp0AAOSwQJhUhyViIt is a boot. It covers the entire bottom of shifter. You can roll under and see it.
That rubber that the levers slide back and forth on is between the 2 plates and I don’t believe it’s sold separately. Boot is a separate item.
these are for the ebrake.That doesn't look like the one I have on my truck.
That might be for a civi rig.
It's actually 2 pieces
See if you can look up
19207-12338291 MFR-27786
And
19207-12338295 MFR-27786
what you are seeing in the pic is the shifter boot..Trying to rubber gasket that goes under the shifter plate. Are these available or do you have to diy
12338291 has the following NSN and secondary part #'sThat doesn't look like the one I have on my truck.
And
