Shipping an MK48....
73m819
327
gainesville, ga.
At your local truck stop diesel pump, as I said JP is just richer diesel
pctrans
19
Bradenton, FL
They don't use it in "everything". Lots of bases here in FL are using biodiesel, not sure about other places.
Jayco36REQS
Orlando/FL
Not if you strap a small camper on the trailer with the wheels taken off the camper.
Tah Da! It's and RV.
I stopped bidding early.. cost of transport too high.. More coming in August, hopefully will have favor owed I can call in.
So I can buy a small popup and strap it to the back? Ok, just the mental image of that is funny! lol
Jayco36REQS
Orlando/FL
We used to put JP5 in the diesel equipment once a month to clean the engines... JP5 is some serious fuel! When I worked at Barbers Point NAS in HI during the first gulf war, the USAF planes that landed on the base loved that we had JP5...
Tow4
669
Orlando, FL
ANY kind of jet fuel smells bad when you are burning it in a diesel. Unless you cut it with a little WVO from the local Chinese place :mrgreen:!!!! I find that 5 gallons of WVO to 25 gallons of JET A will keep your nose hairs from burning out.
For the OP wanting to transport a MK48, that's the way to go. If someone drives it and it takes a $hit on the side of the road; BIG $$$$ tow bill. I don't know if you can flat tow them. If you can hook up the air so you have brakes and they will follow a tow vehicle you might be able to get it off base.
Good luck.
jpinst
Hong Kong/Long Beach
I shipped the trailer from GA and it ended up costing nearly $4k. Even if it can drive on/off a truck ramp, and Fl is much further, the only savings would be in the load and unload which was another $500 (needed cranes)
wreckerman893
Possum Connoisseur
15,643
2,124
I'll be down there in a week or two helping the guys that won the MK48's a few weeks ago.
If you still haven't made your arrangements let me know and I'll PM you my rates and what I'll do to make sure you vehicle gets loaded or moved off post.
