Shop Body Electrics Help
dmetalmiki
2,036
London England
All my shop manuals (T.M.s) are in back of my F350 Ambulance in the new Home for my trucks. (thus) Can Anyone please help me with the wiring for my new Aquisition Deuce 2 1/2 ton shop van (Camper fitted out) with ALL electrics Intact (thank goodness!) exept the pipe for the (still fitted and wired) Army Fuel Heater is cut just above the tank..(where does (did) this go? And I have no Idea at all as to how to Re-Wire (Safely!) the 115 Volt supply and 24? Volt external sockets, (as I do not have plugs to fit them.) Any Idea knowledge and help appreciated. Pictures of Electric Panels and Exterior Plugs includes below..
gimpyrobb
dumpsterlandingfromorbit!
27,791
788
Cincy Ohio
There is a .25 pipe outlet on your fuel tank near the corner of the cab of the truck. A 24v fuel pump was mounted to the 109 box just above the fuel tank. That pipe outlet on the tank was plumbed to the fuel pump and then on to the fuel fired heater. Hope that helps.
dmetalmiki
2,036
London England
Heater Fuel pump
I wish they had left that item On! At least everthing else seems to be there. Is that Heater unit 24 and 115 Volt?.. I would have to use a 240 - 115 vol;t trnsformer , or convert everything else to 240 volt. (exept that heater unit.)
Any Ideas Info on the wiring of the external plugs? (two of)
SCSG-G4
PSVB 3003
5,402
3,507
Lexington, South Carolina
Your wiring plugs, if you do not change them out, will have a considerable dent in your wallet. The two prong plug on the military shop vans is usually a Crouse-Hinds Arktite APJ6275 or equivalent. The six pin plug is also available, with the two large pins probably the ground connectors (ground always makes contact first in this type application). If you think the 6275 is expensive (last time I checked it was more than 175 USD), don't bother with the six pin.
dmetalmiki
2,036
London England
more info wiring
Thanks for that titi-bit..I assume the Red Pin is 115 VOLT?? pos? on the two pin? Input?
What are the required Voltage Pin Inns on the 7 pin input plug please anyone..
checking the tms here again.
quickfarms
25
Orange Junction, CA
does anyone have a used two pin plug for the front of the shop van.
actually all i need is the insert. someone reversed mine so that the one on the body is in a pin configuration and not in the socket configuration.
