shopping for a snatch block
timntrucks
145
Ponchatoula LA
that would do nicely on any 4 wheeler. or maybe a small import truck i have seen some nice snatch blocks for a duece and 5 ton for 75.00 i even have one for sale but im way down south to you
scrapman
deland florida
Champion/Harbor Freight I have had their winches & associated accessories side by side and can tell you it is the same stuff. I was buying it wholesale in lots for resale.
BFR
Rocket Surgeon
2,330
42
North Georgia
I agree w/ Tim. That is meant for jeeps etc. The block might survive being used with a deuce winch, but that sheave is too small and would very likely damage you winchline.
m16ty
223
Dickson,TN
Rizzo and I talked about the Coleman's shatch blocks awhile back. A deuce winch is rated for 10,000 single line pull. If you use a snatch block you should be able to double your pulling force which would be 20,000lb. Now the snatch block is rated at 5 tons (10,000lbs). I'm pretty sure that the block Coleman's sells is the correct block though. We never came up with an answer to the 5-ton rating. Anybody know?
Jake0147
Panton, VT
That snatch block will safely turn back the cable (double the line pull) on an electric "off road" winch that is rated at 8000 pounds by the "rolling loads" method. If you have installed such a winch, it'll work fine. If you have the deuce winch on your deuce, I would continue shopping...
m16ty
223
Dickson,TN
The shatch block in question does look heavy enough for the deuce and looks like, if not the exact same block, as issued by the military for the deuce. The 5 ton rating is what's throwing me off though. Maybe that's the overhead lifting rating which would be less than the pull rating. I don't know.
timntrucks
145
Ponchatoula LA
the 5ton snatch block i am referring to is the one for a 5 ton. its 24 inches long.. weighs in at around 65 lbs. takes a 3/4 cable. most likely rated at 40,000 lbs i had bought a pallet of them and down to just a couple left
hndrsonj
Senior Chief/Moderator
374
Cheyenne, WY
I would guess it's like the deuces load carrying capabilities-very under rated. I am betting the 5 ton capacity of that snatch block will take twice that.
123mack
11
Jemison, AL
The BII list in back of the -10 for the M35 gives a NSN of 3940-00-111-6693 for the snatch block. The description reads: BLOCK, snatch, 1/2 inch diameter wire rope, single 6 in. sheave, w/ swivel hook, 5 ton safe working load. FSCM 19207 part number 11631700
aboonski
West Melbourne Florida
You can even convert a deuce into a crane once you have a snatch block. Some of the TMs show how to do it. I am thinking about using my medium towbar with my 5 ton snatchblock to fabricate a crane just for the purpose of moving a few Chevy small blocks around the yard. The trick will be finding a way to brace the towbar for this application. Once I figure it out I'll post photos accordingly. The snatch block I have is actually made for the larger sized wire rope but will work for the 1/2" stuff.
dentman
Pittsburgh, PA
heavily covered here
http://www.steelsoldiers.com/deuce/30688-gin-poles-finished.html
but im also interested in a gin pole setup so do keep us posted :-D
rchalmers3
30
Irmo, South Carolina
was this what you guys were pondering?
There's a great TM on winching somewhere that 'splained this to me, so here is my understanding:
If the winch makes 10,000# on a straight pull, then the snatch block, taking the place of the anchor point will then receive the 10,000# pull.
It's when you connect the cable hook back to the truck through the snatch block that you achieve doubling at the truck.
I see a possible point of confusion: If the snatch block is called a 5 ton, some of y'all may think the block is for the larger truck known as a 5 ton. Should be no confusion on this: 5 ton in this instance means 11,000#.
That Coleman block appears rated correctly and is very reasonably priced. Think I'll get me one!
Rick
emr
25
landing , new jersey
I have deuce 6 inch correct snatch blocks in NJ for like new 35 also, very nice never used for 45 all factory paint on em...5 tonners 8 inch for 60...if one wants to say they are rating 6 inch for a deuce or a 5 ton trucks 8 inch snatch block and saying it is not enough for said truck is mistaken . they are the way one sizes a snatch block, the wheel length and cable width. personally I would not use anything but the official military surplus snatch blocks, it is just way to dangerous, ...Randy
scooter01922
42
Newbury, MA
And that appears to be what colemans has. I wasn't too concerned with the whole 5 ton thing anyway. Got it mostly for 2 part line action with the 108. Its rated for 8k lbs so i'm figuring i'm well within safe on that snatch block. I think the data plate wants 2 part line on anything over 5k or something.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
After seeing George's little block pull 2 deuces backward at haspin and not break, I doubt the Coleman's blocks would even break a sweat. Scooter, since you have yours, does the sheath pin have a grease zerk on it? I got 2 similar blicks from Sermis. Also, if you want a "correct" hook for your crane, I might have one.
