RangerDave
- 0
- 0
- Bar Harbor, ME
OK OK OK... I have tried searching and searching and can't exactly find out what I need to know... although I think the ultimate answer will be to just buy a 5 Ton!!! and walk away...
Here' the dilemma:
- I need to re-bolt the small shackle that binds the leaf springs together (the 1/4 inch bolt rusted away)
- I want to carry heavy loads safer
- So I am looking at adding a couple of spring leaves to the bottom to bear the weight
- Finding a way to enhance/modify/buy better brakes
- I figure since I had everything apart .... Why Not?????
My M36A2 weighs in at 20,000lbs empty and I've had it on scales loaded to 40,000lbs. I have read countless threads about the overloading capabilities and possible catastrophic events of doing so....
I have seen a bunch of disk brakes mounted on the top of the rear diffs, but I'm not sure the off road mods are reliable enough for commercial use... and I'm sure they are pricey too. What other options for brake enhancement do I have?
I am just asking because I'm sure there are a few of you who have done this type of thing repeatedly... Who like jumping in...
PS: If I replace the axles with better ones then I would have the two axles I need to build the small skidder I want......
Here' the dilemma:
