indy4x4fab
Banned
- 1,711
- 41
- 0
- indy, indiana
We plan to do the same sun shade idea on our m129a2c, rayzer. Trailer is really looking good.
Looks like a mod I will have to do to mine for sure. Just have to figure out a way to reattach my rear support leg! Thanks!!!It was a simple job.
I bought a 2" weld on receiver and cut a hole into the rear cross member to slide it into.
bridged the tube to the second crossmember and welded it up.
I then bought a 7 blade plug and drilled a large hole in the crossmember and bolted it in.
Wired into the 101A2 taillight harness and it works great.
I use the receiver for a bike rack too.
I needed a 6" drop bar to keep things level.
It towed great and rolled smooth.
Just move it off center by a few inchesLooks like a mod I will have to do to mine for sure. Just have to figure out a way to reattach my rear support leg! Thanks!!!
I've got one of those. The method of lifting is w/ a jack in the center (I'll dig up some photos). Because there are no guides in the corners, or anywhere, when it gets lifted it kinda tips (like you would expect lifting something at only one point in the middle).View attachment 395404
I just bought a similar M105A1 trailer. Any suggestions on a method for lifting the top without 4-5 able-bodied men?
Also, Is there a tailgate ladder designed for this unit?
Finally, I'm intrigued by the 1" square cutouts above the fenders which are 21.5" apart. Are there attachments which mount into those holes?
Ha-ha. Nope. Slow and steady on the weekends.That's an interesting thought. I was just going to use wood strips, . . . but now you've got me thinking of alt's
On mine the corners have a line of rivets that make doing both sides of the corner almost impossible.
You should prob start a new thread about your trailer, then we could go on about it for hours, days, weeks, . . . even years (unless you work faster than I do![]()
Whats that like trailer #7 for you???Sold the m416 I posted above, then bought another.
This one has lifting brackets and extended light brackets. Its rough, but the price was right.
Yep 7 in the last year.Whats that like trailer #7 for you???
