Simple Deuce question regards wheels
BaconFarms
139
33
Eagle River, WI
Anyone,
A simple question, please don't read anything into my discription.
With ONLY the frame and axles and steering components of my 1950 REO Deuce with a single rear axel, will a 16R20 on a 12 bolt MRAP wheel, with plate adapter clear everything? I am talking without the body or fenders on. Single axle rear with flipped hubs. All I can see/read so far is them hitting the steering arm, is that correct?
Again, for this question, I am not concerned with cab, fenders, engine, exhaust etc., etc....
I have to travel 3 hours tomorrow to pick up a generator and will be driving past a place that sells the 12 bolt rim. I have the tires already. These rims are 1/4 the price of the 7" offset PLS rims and my plan is to pick 4 up.
Thanks for the help,
BaconFarms
silverstate55
Unemployable
2,126
1,082
UT
16.00R20 tires won’t fit on a stock Deuce, unless you do some serious sheet metal trimming & extend rear tandem suspension dogbones so tires won’t rub treads. A company used to offer an 8-inch lift kit for bobbed Deuces to clear 16.00s (Black Rock Fab? Can’t remember…).
395s are the tallest tire to fit those wheels that will work on a stock Deuce.
As you mentioned, without body parts mounted the 16.00s *MIGHT* fit, but the offset on those steel MRAP wheels places the tires so far inboard that it will be difficult to steer.
