Pump is dry internally. It used a splined coupler to run the pumpDoesn't appear to be any gasket at the pump fitting, is that not needed, or am I just not seeing that right?
Simp, Are you kidding about using an abrasive blaster to spray Behr paint? I plan to paint my 934 with Behr. I was planning on renting a good airless sprayer to do it. Did you thin the paint at all?I use an jobsmart abrasive blaster found at tractor supply. It shoots the Behr paint really well.
I am not fond of behr anymore. I have gone over to sherwin Williams industrial enamel.Simp, Are you kidding about using an abrasive blaster to spray Behr paint? I plan to paint my 934 with Behr. I was planning on renting a good airless sprayer to do it. Did you thin the paint at all?
By the way, your truck is awesome!
For $24, I'm tempted to buy one to try it. You do anything special to spray paint with it?And yes i use this. https://www.tractorsupply.com/tsc/product/jobsmart-handheld-abrasive-blaster
I do not thin it at all.
Nope. Usually its just one pass to cover any color. On the 915For $24, I'm tempted to buy one to try it. You do anything special to spray paint with it?
Nope. Just fill and spray. A good water seperator on the tank is neeed as it will have the compressor running hardFor $24, I'm tempted to buy one to try it. You do anything special to spray paint with it?
If and when the Allison goes out I've got everything to swap a CAT in. The CAT is 95% efficient on power so not nearly the power loss as the allison has. I prefer the cat at times for pulling hills. I prefer the Allison at times, especially during stop and go driving, or running around empty.Wes, after putting a lot of miles on it, how do you like the stock transmission vs. the 16 speed CAT transmission? Are you planning to leave the existing transmission in the truck?
I did similar with mine :-I will be adding some ground spade brackets and spade mounts for behind the cab. The 915 weighs in around 22,000lb but it easily drug in while winching something heavy to get it into position for loading.
