banditt1979
- 738
- 93
- Cincinnati, OH
I am attempting to convert my single circuit brakes to dual circuit on my 71 M35A2. I have acquired a master cylinder MC39577, an extra long air pack, and a spare single circuit mc bracket to modify. Still need to find or purchase an additional air tank, and possibly a combination valve to isolate the brake lines should one fail. That part I'm not completely sold on but would like to have it as an additional safety factor.
I've taken some measurements and determined that the new mc is 3" longer than the original single. So at a minimum I'll need to cut back 3" off of the bracket, maintaining the original height location, and weld in a plate to bolt it to. Then need to check geometry to the brake pedal. Looking at the A3 and air force setup, the connection to the brake pedal is offset from the brake pedal lever. Maybe I'll use a heim joint to make that connection? Not sure yet. Also the dual mc mounting flange is wider than the single, so there may be issues with drilling and tapping the bolt holes, at least at the top. I am still researching and taking pictures and measuring, so this won't happen very quickly. I've already rebuilt my single system and it is working fine as far as I can tell, but while I have the time I would like to do the upgrade.
I saw in one of the other threads that someone had done something like this and bolted in the new mounting plate. Depending on what I can get done at home with my tools or at work with the saws and CNC, I may do a bolt in or weld in plate. More to come!
PS I have a workbench in the laundry room which is normally used for early planting for our garden in the fall, so never mind the background
