Slave Cable Install ?
dabtl
Denton, Texas
Got the two pin slave cables.
How are they hooked up to the batteries? I could not find a TM section on them. Of course my search was limited and it is easier to ask the experts here. :D
halftrack
11
New Orleans, LA
Are you talking about slave cables themselves or what the cables plug into on the vehicle? If you are talking about installing the slave cable plug itself then the negative is grounded to vehicle frame and the positive lead is connected to the positive terminal on the last battery in the series.
FreightTrain
Banned
2,730
13
Gadsden,Al
Yea,Short wire goes to a grounded bolt in the cab and the long cable goes though a hole in the floor(clean the dirt,rust,sludge off the rear corner and you wil find it,hit it with a screwdriver and hammer to pop it out) and to the front batteries positive terminal.
FreightTrain
Banned
2,730
13
Gadsden,Al
Well,that ain't gonna happen Craneboy.Atleast not with teh deuce kit I have.The Ground lead is only like 12" long.Barely makes it to the floor.I Grounded out to the body.Yea,Another item designed by an idiot built by a moron.
dabtl
Denton, Texas
OK, I kind of thought that was the way to install it. But, why buy a lot of parts that were working when you begin because you did not ask how not to screw it up.
cranetruck
75
Meadows of Dan, Virginia
You probably have the wrong slave connector/recepticle/cables, both cables are 32-1/2 inches long for the M35 (fig 333 in the -20P)....craneboy, huh!
Kind of funny actually.
cranetruck
75
Something about the multitude of things to make you wise.
jasonjc
289
Gravette Ar.
FT are you shure it's for the deuce?? Those plugs are used on just about evrey thing in the military. On all my trucks the ground goes down to the frame.
FreightTrain
Banned
2,730
13
Gadsden,Al
well,the seller stated it was for a M35A2 blaa blaa blaa.I know it fit like a glove when I yanked that cover plate and the hot lead is just long enough to reach.
rmgill
14
Decatur, Ga
Why not get a longer cable and attach it to the slave plug so you can run it to the batteries? Or you could get a shorter cable and run that down to the frame to get a better connection to the bolt connecting to the ground lead you attached to the cab sheet metal. That'd give you an additional grounding path over the one that runs from the engine to the cab sheet metal and then back to the frame.
cranetruck
75
Ideally, each device should have its own dedicated (ground strap) ground return.
The frame is then connected to the batteries.
The starter motor/engine is connected to the batteries.
The cab is connected to the batteries.
The instrument panel has its own ground return to the batteries and the panel itself is insulated from the cab.
The best place to connect an external battery (slave cable) is to the vehicle batteries, since it then serves all devices connected to them.
Again, the 757 is wired this way......
Many add-on devices, like the VIC-1, fuel burning heater, headlights, BO head light etc have grounds that rely on the wiring, not the case, which makes it possible to adhere to the above convention.
dabtl
Denton, Texas
Don't forget to put the grommets in the floor holes.
The actual measure is 1-1/2 diameter with a groove diameter of 1-1/4.
I could not find any other than at O'Reilly, where in frustration I bought a generically labeled GM PCV Valve grommet # 42061. Perfect fit! :D You will know it when you see it is all I can say. I used some white lithium grease to ease the wires through the hole in the center.
sermis
17
Temple, TX
Mine has one long and one short cable. Short one is grounded to one of the bolts on the plug. I have a couple others that are the same way.
73m819
323
gainesville, ga.
mine has one long and one short, one is connected to the- the other to the +
cranetruck
75
sermis said:
....Short one is grounded to one of the bolts on the plug. I have a couple others that are the same way.
That's not correct, even a connection to the cab would be questionable. You want a solid path to the start motor ground connection.
There are butt splice connectors available to lengthen the cables, some are crimped some are soldered.
