- 34,010
- 1,827
- 113
- GA Mountains
What are the odds of re-cabling a slave plug completely? I have one with just horrible cable.
Ryan, you are correct, but it helps to know what the ideal wiring should look like. Two connections at each battery post should be the limit IMHO.rmgill said:Bjorn, wouldn't all those connections to the neg terminal be a problem on the terminal? Better to build a bus bar or single ground point that has a good solid current return path to the negative terminal.
Good question, I have never tried to take one apart, I have one with burnt connectors and may give it a try one day.Recovry4x4 said:What are the odds of re-cabling a slave plug completely? I have one with just horrible cable.
So doubling up would be the best thing with the slave cable since you're going to be feeding heavy current over it. A paired connection from it to the cab sheet metal AND to the frame would be good because that'd allow for two paths (redundancy is good). The frame's probably the best ground to maintain because it should be good all over the truck (heck of a grounding busbar).cranetruck said:Ryan, you are correct, but it helps to know what the ideal wiring should look like. Two connections at each battery post should be the limit IMHO.rmgill said:Bjorn, wouldn't all those connections to the neg terminal be a problem on the terminal? Better to build a bus bar or single ground point that has a good solid current return path to the negative terminal.
You need to make the trip. I think I have a couple of the 2 pin.ken said:Are the 2 pin cables still avalible? I could only find nato style. So i converted everything to the nato plugs. Sure is easier hooking them up in the dark to.
Saturn has the two pin to NATO adapter. Should work in reverse. $18ken said:Are the 2 pin cables still avalible? I could only find nato style. So i converted everything to the nato plugs. Sure is easier hooking them up in the dark to.
