Slow blinking turn signals
pinwormfood
easton, pa
hi guys, new problem here. I am going down the road with my lights on and go to make a turn and my blinkers are going suuuuuuper slow. so i turn my lights off and try again and they run at full or almost full speed. I also noticed that the batt guage was going back and forth as the blinkers go off and on....
any ideas, my guess is the battery is on the fritz and may need to be replaced.
also, which battery runs the lights and electricals....thanks, pinworm
McCluskey
Anytown, USA
I don't know how to speed up your blinkers, but I do know it's your front battery that runs your lights. Your back 2nd battery really is only used for 24v items. The front is used for all 12v.
lindyp38
ulster county ny
on my 65 ford..i had the same thing happen......i replaced the bulb....and used dielectric grease...and problem solved.....
check those bulb contacts..they do wear down...over time....
just compare a new bulb with urs.......
ralbelt
9
West Warwick, R.I.
Ditto on what Lindy sayes, and clean grounds.
And always remember the first rule of owning a CUCV. If its rubber replace it,if its electrical clean it.
Warthog
245
OKC, OK
Easy one.....you haven't changed you blinker fluid yet.................:cookoo:
Seriously, it may be time to have the drivers side alternator rebuilt (GEN1). But 1st have your batteries load tested.
pinwormfood
easton, pa
Findings
ok guys, i tightened the alt belts per the manual (-20) and i load tested the front battery...it came up short and it says to replace it. i will do that for sure, but i was wondering what the procedure is for checking the alt output without the ice setup. i have a multimeter and have half a brain if someone can set me up with the procedure. thanks, pinworm
