Smokey 1009
jag7720
Kansas City, MO
If you know who Marshall Booth is (may he rest in peace) then you will know that that article is trustworthy.
I used to do this on my MB all the time and it works.
maritimer
Yarmouth, NS
check your air filter
have your timing checked
presure test your coolant system
is the exhaust white only at start up or is it white all the time?
dependable
187
Tisbury, Massachusetts
Run and drive it until it gets up to temp. Does it ever get to temp? Should be running over 180 d f after a good drive. check thermostat if engine does not get to temp, it will do damage to keep running cold. Check recent thermostat thread. If it only smokes when cold, I agree with hobie237's post above. If still smokey and if you are loosing coolant, than Maretimer has it right.
