- 12,195
- 328
- 0
- gainesville, ga.
Remember, the CABLE dia. is matched to the snatch block pulley, use a 3/4 cable in a 5/8 pulley will pinch the cable, causing cable damage and failure under load, using a 3/4 cable in a 7/8 pulley will allow flattening, causing damage and failure. A pulley is designed to SUPPORT the cable on the sides as well as the lower part, the bigger the difference in size of cable to pulley cable design, the faster the failure under load
