Snow chains on FMTV tires
ramdough
1,729
Austin, Texas
Do the Pewag 395/85-r20 chains with the MRAP stamp on the cams fit each tire option that came on the FMTV’s the same?
The reason I ask, Pewag’s web says that the dash number chains are for 14.00R20’s but I confirmed with other forum members that the ones marked MRAP are the right ones for FMTV. So, does the tread version make a difference? I have MVT’s.
Thanks!
tennmogger
541
Greenback, TN
My 2c, an LMTV would be the last vehicle I would try to run chains on due to all the air lines in harms way of a loose chain. But, you didn't say what vehicle the tires were on!
ramdough
1,729
Austin, Texas
I watched a YouTube Army training video on installing the chains, but they did not mention the little cable piece.
I could not tell by looking at one what it was for.
ramdough
1,729
Austin, Texas
I re-read the TM for a 1083 regarding snow chains. They only listed instructions for the rear 4 tires. Is that because there is only a trick to get them on the back or are they implying that you should not install chains on the front wheels?
ramdough
1,729
Austin, Texas
Anyone know this answer?
Thanks!
