tshermankb
- 0
- 0
- Portland,Or
boom
is it possible that your is not a virgin? someone has been there before you?OK, I'm a little confused here. Is the glass ball in the bottom of the piece on the right in the attached picture or is it in the piece on the left?
The piece on the right is clean straight through. Nothing in mine.
The piece on the left has a valve I can push on and it will open up allowing carb cleaner through, but there isn't a clear glass ball anywhere in it. I tried taking a picture of the top and bottom of it, but it didn't turn out very well. The piece that I can move upward is more like white plastic.
So am I missing the glass ball?This is giving me a headache.
I'm at least the second owner. I actually bought it from a guy on here and he said he had bought it from the army base.is it possible that your is not a virgin? someone has been there before you?
Is the replacement check valve a steel ball? When I had my IP rebuilt I swear the fella said he used an upgraded check valve for the return line.The parts number is GM 14067420 or 23183.
I have never checked but you should be able to get them from any Stanadyne parts house. I doubt you will find it at NAPA
I think you will be needing a injection pump soon. I punched out my ball I am going camping this weekend with it then its time to get a iinjection pumpI'm at least the second owner. I actually bought it from a guy on here and he said he had bought it from the army base.
So if the glass ball is supposed to be in the piece on the right; and all the gunk I keep cleaning out is in the piece on the left, then does that mean the IP is getting ready to go? Last night would be the 4th time I've had to clean it out. It's been about a month in between the 2nd and 3rd time I had to clean it.
It's ran fine today to work, we'll see what happens when I try to go home again tonight.
I believe I saw that someone had posted that you can't get the return fuel valve from Chevy anymore, but you could get it somewhere else. Perhaps I'll try to buy a new one.
Just jumping in here and have never done one but I would bet the one on the right is just a brass nipple fitting. No glass no ballsIt would be in the piece on the right. Someone prior to you must have punched it out.
