Ford Mechanic
- 10
- 38
- Edenton, NC
Dirty old man, get you mind out of the gutter!Ummmmm, really?
Yeah, I probably should have worded that better.
as requested this is my "Package" including the my "Special Tool"
SweetView attachment 599051 as requested this is my "Package" including the my "Special Tool"
all sockets are craftsman and can be purchased individually if you want build yourself a kit..
Start from left to right:
14mm 6-point 1/4 drive with the drive end drilled out just large enough for a 1/4 drive extension to slide through it.
View attachment 599052View attachment 599053
Next is a 10mm 6-point 1/4 drive socket, and
9mm 6-point 1/4 drive socket that was cut down on the end to work as a spanner socket (used on the pump with the alternative locking nut)
and 3 inch 1/4 drive extension ( you will also need a 1/4 drive ratchet)
View attachment 599062View attachment 599071View attachment 599072
ALSO the modified 9mm works great for turning the governor spring tensioner nuts. (I turn them 3 Clicks on each to start with)
I have a pretty good right up on doing the pump adjustments:
(this is a compilation of photos and info from 44 pages for post/photos)
but it is easy to print off and have with you while you work on the truck..
I bought the same and have not yet installed. Please tell more. Are you manually shifting it then, or does it just shift harder when left in 1-5? How far have you pushed the top speed so far? Did you swap out all the springs they supplied, or less?I run the pacbrake 4k springs works great.
Simple way to understand governor springs is that the more tension is on the springs (whether it is from adjusting the stock springs or installing aftermarket springs) the higher rpm the engine will rev to before it begins to remove fuel in order to control the max rpm of the engine. Governor springs limit the rpms of the engine by removing a portion of the fuel going into the engine at the higher rpms.Thank you all for doing the hard work here. I am building my kit now. Read all 45 pages three times now. So I know just enough to be dangerous.
Question, I haven't seen answered. I understand (basically) how the governor springs work. What I am not understanding is the functional difference between adding preload to the stock spring and going with an aftermarket 3k spring such as the pacbrake.
Any input, experience or guidance?
The Pacbrake 4k GSK (gov spring kit) comes with multiple springs of different lengths and tension and I installed all of mine except for the very last one (the 4k spring) and as shown in the vid I posted earlier in this thread will limit my truck at 2800 rpm which I am happy withI bought the same and have not yet installed. Please tell more. Are you manually shifting it then, or does it just shift harder when left in 1-5? How far have you pushed the top speed so far? Did you swap out all the springs they supplied, or less?
The answer to your question:The difference between the two is a matter of spring rate (k). The stockers can only be cranked down 2-3 "clicks" before they become unstable in operation. Example, the engine may not be able to maintain idle control response time. Engine may then die when trans put into gear. If 2 "clicks" of the stock springs is not enough to do what you want, one should then shift to the aftermarket springs to increase top RPM yet still keep the governor operation somewhat content. But, as posted above, when using the aftermarket springs, the throttle hold cable can't really be used for any RPM over 1400rpm. But, if this is for a hydro PTO pump, the manual doesn't want you running it over 1800r's anyway.Thank you all for doing the hard work here. I am building my kit now. Read all 45 pages three times now. So I know just enough to be dangerous.Question, I haven't seen answered. I understand (basically) how the governor springs work. What I am not understanding is the functional difference between adding preload to the stock spring and going with an aftermarket 3k spring such as the pacbrake.Any input, experience or guidance?
I'm curious about the turbo too. I was always worried that a larger turbo would mean more turbo lag. As a reference point, what is the max boost produced on a stock 8.3?More info please. What turbo and what is boost level now? There is no fuel plate in the Bosh MW pump, that popular mod is done to the Bosch P7100 pump, so that part doesn't make sense. What is the highest EGT, RPM, and top speed attained so far? Measurables help to quantify better than the opinion dyno. Also what place changed the pump timing and the cost to do so if you would be willing to say? The 5.9 GSK's supposedly have a lower result in 8.3's. If it is a 3000k spring kit, then it will produce like 2400rpm on an 8.3, or something like that. Not sure if that is actually true yet or not.
Thanks for the post, we look forward to your detailed reply.
I usually don't have to push it to hard so I just normally let it in 1-5 unless pulling grades. You can manually shift it if you want, the highest I ran RPMs so far was 2700. Top speed isn't what I was going for but it will move. I used all the springs supplied in the kit when I put it in. The only draw back is setting high idle for pto operation. Anything 1400 rpm and below is fine but try to go any higher and she takes off. If the pto is engaged that slightly loads the engine and it will stay around 1500 but if your in the cab you can fine tune it with your foot without using the throttle cable. I used all the springs so it has full fueling to whatever RPM I decide to run it to, so it doesn't start pulling fuel around 1800-2000 like stock.
