SoCal 2016 Summer Rally Aug, 5-7 Big Bear California San Bernardino Mtns. camping
JDToumanian
15
Phelan, CA
Hmmm, a convoy right past my house will be hard to resist... What is the dirt road like? I've never been that way. I don't do camping anymore, I just don't enjoy 'the outdoors' where there are bugs and where there is not a soft, orthopedic bed and climate control, but I may be up to joining in on the convoy and hanging out for a few hours if the road isn't too rough for the HEMTT. I'm not worried about it getting stuck, I'm worried about rocks chunking up $8000 worth of tires. Hairpin turns would also get annoying real fast... The HEMTT has the length and turning circle of a school bus.
Jon
JDToumanian
15
Phelan, CA
Actually, if I went to my local Michelin truck tire dealer and ordered them brand new, paid disposal fees, taxes, and installation, the cost would be well over $16,000. A set of 8 good used surplus take-offs would be around $4000. Fortunately my truck had a brand new zero-mile set of tires when I got it, but I am paranoid about ruining them.
Bad_Carp
53
Palm Springs, Ca
Dry rot from the HEMTT sitting in the driveway is probably more dangerous to the tires than a little road trip!
I should note that my truck sat for about a year and I had to replace 3 tires that were too badly cracked, the heat out here kills everything!
Another Ahab
4,905
Alexandria, VA
That's not paranoia (that's a lot of coconuts); that's calm reason and pure logic kicking in. [thumbzup]:beer:
JDToumanian
15
Phelan, CA
I know this doesn't cover all of the trails but most are no more extreme than this vid. There is 1 turn that is kind of tight from what I remember, had to make it a 3 pointer in my 818
Road up from the desert is mostly sand-dirt and not too rocky.
Perfect. Thanks for the info... I'm definitely going to try to make it, though I might have to work that Friday afternoon so I may have to bug out pretty early. I never know though, my schedule changes often, so I may end up with that day off.
I use Miller Tire Paint... That's how you protect tractor or equipment tires, so they don't rot out before you wear them out. My deuce tires have been on since 2007 with Miller Tire Paint applied about once a year or so and they are still perfect. It makes them look great too!
Jon
Bad_Carp
53
Palm Springs, Ca
Jon
I will have to look into that, not sure if it could protect from the heat out here, but if it would even help a little bit I might consider going to super singles, just not willing to do that when the heat can destroy tires here so fast on a vehicle that doesn't get as much use as I'd like.
Another Ahab
4,905
Alexandria, VA
Jon
I never heard of that product. So it's more than just a tire 'dressing"; actually a rubber preservative?
JDToumanian
15
Phelan, CA
Yeah, great stuff. Made by Miller Tire Company, I discovered it back when I bought my deuce tires because I was looking for a true preservative / protectant for tires, not something just to shine them up. It smells like latex paint but it's more than that... When it dries it's stretchy like a rubber party balloon. Comes in a plastic tub, it's black, kinda thick like grease, you dilute it with water (I can't remember, maybe 4 parts water to 1 part paint). It can be sprayed on or brushed. I always brushed the deuce tires, usually jack up the wheel and rotate it as I brush it on, but I'll probably spray the HEMTT tires because I want to coat the tread too... HEMTT tires like to crack down between the tread lugs.
Jon
Gripy
Los Angeles, CA
Who I understand will be there.
Gripy
Blendmaster
ProspectorGM
Fastnova
True Knight
SaltyDeuce
Leo 4x4
Bad_Carp
Novacainefix
cycletek
At least 10 who should be there.
As last year I will bring burgers and hot dogs to help with dinner on Friday evening.
Blendmaster; Do we have running water this year and are campfires going to be allowed?
We usually use CB ch5 so, I assume we will use this channel again.
SO, close I can feel it!
