Soft top install
Thunderbirds
381
Northern Black Hills South Dakota
Quick question- I’m installing a new soft top and I’m running into trouble. How do you get this part in that part? I’m running out of options.
Flip the cover upside down, lay it over the front. Have a helper with you, slide the lip into the channel from the side. Left to right or vice versa doesn't matter... Then flip the cover over the cab, There should be some videos online as well. (https://www.google.com/search?safe=...ate=ive&vld=cid:d23d8832,vid:Q574QUoxA4A,st:0)
Good luck.
