Solar battery Charger hook up..
ericp351
106
erie Pa
Hi all. My 91 M925A2 came with two battery charge panels in front of windshield. The wires are cut under dash. How do I hook them up to maintain my batteriers? I still have the four 6volt batteries dated 2012. Is there a reference in a TM? I looked a bit, but could not find one. Do these solar chargers normally work? Thanks for any info!
elkhtr
12
Stanwood, Wa.
I swear by the solargizer setups.
My 923's batteries were in marginal shape when I bought it.
Installed a solargizer system, came back a couple of weeks later and it started like they were new.
Re tested with a load meter and they had improved.
The problem you may have is that the controll boxes may be missing.
Look for some small boxes with a red l.e.d. connected to the batteries.
MtnSnow
15
NSL, UT
Yep. what Elkhtr said about the "controller(s)" might be the killer of re-using the panels if they are missing.
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Just so you know, it isn't a charger.
Its a solar powered system to keep your batterys from sulphating(sp?).
elkhtr
12
Stanwood, Wa.
[h=1]24VPSC REV-F PulseTech Solar 24-Volt Battery Charger Desulfator[/h]
Part #: 735X643 Model #: 24VPSC REV-F
The PulseTech 24VPSC 6.3-Watt 24V Solar Charger charges and desulfates all kinds of 24-Volt lead-acid battery systems (conventional flooded, sealed "maintenance free" VRLA and AGM). Safe, reliable and weatherproof, the solar-powered unit prevents dead batteries by keeping them in like-new condition all the time. The 24VPSC REV-F comes with a Push to Test feature that instantly shows the batteries state of charge. Lugs on the battery lead connect directly to the battery terminals.NSN 6130-01-497-0964
These are what I have.
Mfg says they charge
Daybreak
2 Star Admiral
1,522
774
Va
Howdy,
You might have the standard GSA one which is Part #: 735X640 Model #:24VPSC
It sounds like you are missing the control box (or boxes)
gimpyrobb
27,787
778
Cincy Ohio
Ok, little lesson in power here.
P[SUB](W)[/SUB] = I[SUB](A)[/SUB]× V[SUB](V)
So, 6.3watt divided by 24v equals .2625
Yes, the unit charges at a fourth of an amp, my bad, its a charger.
Your best bet is to consider it a battery conditioner for all practical purposes.
[/SUB]
ericp351
106
erie Pa
Thanks- looks like last owners took/kept the controller boxes. Sounds like ea. box- panel set would be for 24 v, not 12v ea. panel, correct?
