Solargizer
Mike_L
9
Marion, IN
Yep, but I see he ships UPS which is a little more than USPS sometimes. I've noticed a lot of vendors ship that way or via a flat rate that seems steep. If I see that and think it could be cheaper, I always contact them and ask them if they will ship flat rate Priority or Parcel Post or Media (for manuals and like). Most of the time they are willing to do so. Every once in a while, someone will say no and then I don't deal with them if I can find it elsewhere.
My Solargizer shipped for free when I bought it a couple years back off ebay. It came in the little white factory box with Priority Mail labels and I think it had about $4-5 postage on it when it showed. Still, with free shipping, I paid $50 so all in all, not a bad deal.
319
Lieutenant
3,347
58
Michigan
"...it is mounted on the hood..." Darwin T
I've been keeping mine inside the passenger window leaning against the latch. It'll be tarped for the winter so that won't work.
I take it from this post that the solar panel is generally weatherproof, correct?
Panel is weatherproof and should be mounted outside in direct sunlight. Per a conversation I had with a tech at Pulsetech, he said the effectiveness is dramatically reduced if behind glass, especially tinted glass.
SteveKuhn
Hasbrouck Heights NJ
"...the effectiveness is dramatically reduced if behind glass..." - 319
Makes sense but I didn't consider that. Outside she goes. One of my friend's jeeps has it outside too and he's had it for some time. No trouble.
Steve
360
southern ca
just bought a solargizer for 40 bucks from ebay and am looking forward to mounting it up on my m1009.
where do most of you mount these on the roof or on the hood near the base of the windshield?
AmericanHaole
Los Angeles, CA
I just bought one for $40 and plan to put it on the hood on the passenger's side like Darwin from Texas described.
For standard batteries, I think everyone should consider de-sulphation tool. I happen to think Solargizer did a great job at that price. I wouldn't have considered it if it was hundreds of dollars.
The people who have contributed to this thread have been very knowledgable and helped me make an educated decision. Thanks. [thumbzup]
Rustygears
Ramona, CA
I put my solargizer panel on top of the hardtop cab for max exposure. It's pretty much invisible from any angle except looking down from above. I used RTV to attach it and also used a couple small blobs of RTV to dress the wires inside fiber sleeving along the back of the cab. I mounted the control box inside the battery compartment on the outside of the battery tub with the LED facing out and used a set of Powerpole connectors to attach to the battery terminals.
wsucougarx
Washington State
Just bought 3 on ebay for $30 each;-). They were listed for more but it never hurts to ask if they'll accept a lower price. Paid off this time;-). Two units are going in my "5 ton anticipation" box.
HighPlainsPrepper
Pierce County, WA
Solargizer Technical Question
I've read somewhere that if you have 12v batteries connected in series giving you 24v, and you also have one battery tapped for 12v, then you should be using a multi-bank charger.
So the question is, if a guy had two IS-24-L (6-24v) chargers, are there any benefits to using one on each battery, or is this just a waste? I'm leaning towards just hooking one side to the negative of the front battery and the other side to the positive of the rear as that seems to be the popular way to do it.
Discussion? Pros/Cons? Thanks.
