Source for New M1008 Radiator?
WWRD99
1,697
York Pa
That looks like the newer style clip in hose end. I'm not sure but there could be an adapter out there from that to the metal line.
ALLOYWORKS 3 Row Radiator For 1982-1991 CHEVY GMC C/K 1500 2500 3500 Suburban 6.2L Diesel https://a.co/d/eI8mIYa
Sent from my SM-S906U using Tapatalk
Tinstar
1,766
Edmond, Oklahoma
They still make the copper/brass radiator.
Expensive but literally drop in.
It's exactly like the original
Any radiator shop will be able to order it for you.
I don't have the part number in front of me but I showed it in an earlier thread a few years ago.
It's been flawless for years. No issues.
  • Like
Reactions: 98G
Jeepadict
673
Round Mountain, NV
I like Champion in SoCal. They make a very nice piece, reasonable price too. Whoever you talk to to order whatever you decide, tell them you have an '84 K30 with 6.2L Diesel and TH400 trans...do not tell them it's a CUCV, it just confuses most folks.
Sent from my SM-G970U using Tapatalk
WWRD99
1,697
York Pa
Yes but you need the connection for the heater hose. It's 16x1.50 if I remember right. Had to buy one.
Gormin
Skopje, North Macedonia
Almost finished installing an Alloyworks radiator on my M1009, the oil and transmission line fittings are a direct fit.
There was additional work around the heather hose and the coolant level sensor fittings because in my case radiator came without fittings for this inlets. Both inlets are 16x1.5 in size.
For the heather hose a fitting with an O.D. of 19 mm is suitable.
I had a issue with the coolant level sensor because I couldn't find a fitting deep enough to accept the sensor and so I had to make the same one on a lathe.
Also I have installed new radiator bushings and they needed little trimming because new radiator is too wide for them. Without trimming radiator sits high and cap is hitting the hood when you try to close it.
