source for upper radiator hose for MEP-803a
Hard Head
22
Greenville SC
The upper is a 32MM 1.25" to 28MM 1.12" hose with a 28mm id. The lower is a 1.25" id hose. I have put flex rubber hoses on it that I picked up at Advanced. It would work. See pics. I am waiting to find out how much more a direct replacement or a cuffed silicon hose for the lower.
Farmitall
280
Eubank, KY
View attachment 720007View attachment 720008
Thank You Sir!! That is great info to know......saves me the parts store browsing and takes away the guess work....but I'm still in for the other silicone sets if they get made.[thumbzup]
Farmitall
280
Eubank, KY
Those universal hoses are no where near the quality of a molded hose. There also about half as thick.
Maybe so but its still better to have one on the shelf in a pinch than be searching high and low for molded hose with the generator down when you need it.;)
They are easy to come by and they are inexpensive.
Bmxenbrett
30
For an emergency for sure but if i can get a molded hose il take one...that is what this thread is about.
Hard Head
22
Greenville SC
Well this will not be cheap by any means but I am going to R&D it on two of my generators (802 and 803). It will cost around $200 per hose for the tooling. I ordered two lower hoses for testing in hopes of not having to make a custom one. I also purchased parts to make and test 2 upper hose prototypes. There is a cost to ship and also exchange rates factor in on the costs when ordered. Now I wait for DHL.
Hard Head
22
Greenville SC
Well after much debate and looking at 802's and 803's I decided to do a hose design change. I didn't like the 2 90's since the hose practically bumps into the muffler on the 802, not the 803. So I reduced the bends by 45 degrees. The new hose will be totally away from the muffler. As I mentioned earlier no issue with the 803 just close on the 802. I just cut several hoses to make my prototype to send to England. They will tool and send back a one piece prototype to accept for manufacture.
Original top on 803
Design change
I did test the flex silicon hose for the lower hose replacement but decided the bends are too tight for the size of the hose so I will send a lower hose for mfg in silicon as is.
Light in the Dark
6,534
MA
I think a lot more folks need to commit, if this thing is to take off the ground. But thats just my perspective... I am not the one having the things made.
Demoh
26
St Pete, FL
Id be in for at least 3 sets if priced accordingly (knowing they will be higher than what I could get today) and possibly more depending on if I end up getting more gens with blown hoses or not. Thus far out of 7 ive been pretty good.
I do like the modification as I use an 802 as a primary and only use the 803 when more juice is needed.
