South Wind Engine Heater
M543A2
11
Warsaw, Indiana
I put a South Wind 939J24 multifuel engine heater on my M543A2. I think it is a really good addition. It heats the engine nicely. I considered using an electric tank type heater, but if the truck is away from a power supply, it cannot be used. I leave the heater on when using the truck for short times on light work which would not normally warm the engine enough to dry it out. The heater will help get it up to temp quickly. Does anyone else have one, and how do you like it? The company is based here in Indiana. I called them, got a manual for the heater, and the information that all parts are available for repair.
Regards Marti
cranetruck
75
Meadows of Dan, Virginia
Marti, is that the coolant heater AND the oil pan heater, did you complete both installations?
From the installation instructions I have seen, they do go together, using a pump for the coolant and the exhaust from the heater for the oil pan.
I'm wondering how effective the oil pan heater would be alone. Last winter I drove a VW diesel rabbit while working on a heated fuel tank addition and found that a magnetic oil pan heater worked great alone (110 VAC).
I'll be concentrating on an oil pan heater for the 8x8, which will speed up cranking rpm, reduce current drain for starter, reduce time to oil pressure and no need for multi grade engine oil ( I use 30 weight).
M1075
Oklahoma City
I just posted a classified listing for a new-in-crate coolant and oil pan heater kit from South Wind. I also have a new-in-box fuel burning personnel heater kit listed in the classifieds.
