Soviet Vehicle Starting
Coltman15
12
PA
Hello all,
Dumb question but can you use a nitrogen bottle to start Soviet Air start diesel engines or does it have to be strictly regular compressed air?
Coltman15
12
PA
I would imagine compressed air as the vehicle would have its own compressor and air bottle(s)
The reason I ask is my electric starter failed, so I cannot build air pressure and need that first start. High pressure Air compressor filling stations are not common but nitrogen is. Would I be ok to get the first start using a newly filled nitrogen bottle?
19,326
I would be concerned.
If you have a full tank of nitrogen - and no regulator - and you put 3000 pounds into a hundred pound air line you might have a really bad day.
Coltman15
12
PA
Pressure is not a problem. The vehicles run on high pressure systems, 2200 PSI. Nitrogen tank is filled to that. I’m more asking if the injection of nitrogen on the top of the cylinder head would evacuate all the oxygen, not allowing the right fuel air mixture.
19,326
My best guess is that it will turn over and in another turn or two, the nitrogen will leave through the exhaust - bringing your air/fuel mixture to more reasonable rates. Air is 78% Nitrogen, therefore if you accidentally mix pure nitrogen with air, nothing bad will happen.
Coltman15
12
PA
find out where the fire brigade get there Breathing Apparatus sets re filled ? Why not start it using the batteries ?
Fire brigade scuba units have different valves and federal law does not allow tanks to be filled without the proper valve design for the type of gas being used. Breathable air, compressed air, nitrogen, O2, all have specific filling valves. The tank in the armor is a nitrogen tank/valve. And the electric starter is burn up, so the only alternative is air. At least until I can get a starter imported.
19,326
Okay! Well then, you mentioned "The tank in the armor is a nitrogen tank/valve." so I guess you should be able to fire that baby up! Even solves my question about over-charging the starter with several thousand pounds vs a hundred.
Any chance you could shoot us a picture or two?
Maybe even the bottle where the nitro is plugged in?
AND, it doesn't matter if it needs paint or not.
We would just love to see what you are working on...
