Spacer block size for Bobbed Deuce
Avn-Tech
31
California City, Ca
Group,
I have tried to search the database for info and found two different answers.
I am helping Shannon Deese bob his deuce and need the dimensionfor the rear spring blocks. I have seen 3" & 4 " listed, So should the blocks be 3" or 4 ". I also need the width of the block for the machinest.
Avn-Tech
100dollarman
Lucerne Valley, Ca. 92356
The front springs are desirable, but we have done several with blocks too. 4" tall is what we make them. I make them with "ears" so they cannot move, and I think it gives them a bit of support. Also- since these pics were taken, I have been using 3/4" u-bolts instead of 5/8".
Not 100% sure of the legalities-- but I believe a 4" block in the rear is legal everywhere.
I have offroaded the block set-up with little to no axle wrap on a bobbed Deuce on some of the most treacherous rock crawl trails anywhere. (The "Hammers")
Here are a couple of pics-
Hammer
398
Winlock, WA
I copied ^^^ for lift blocks. No problems yet.
I have the 3/4" U bolts, but used the lower brackets from the dog bone. Everything bolts up, and if I ever get the front shock setup, it will bolt in place of the current lower bracket.
