Spacers to run hummer tires and rims
Chaski
56
Burney/CA
2" thick 8 X 6.5" spacers with 9/16" studs. I have not ever bought any, but if I did I would want steel ones. You will need spacers in the back, the tires will hit the inner wheelwell. You can find the aluminum ones for about $110/ pair, the steel ones are more. They can be found online from multiple retailers
beltfedonly
Wilson/NC
I have a pair of the 2" spacers that you need. They are new and come with the lug nuts. Bought them to use on my M1028 but sold the vehicle.
$100.00 for the pair.
Beltfed
4,744
beltfedonly
would these fit the M1009?
No. The M1008/1010/1028/1031 trucks are all 8 lugs. The M1009 is a six lug pattern.
The only way to make HMMWV wheels work on a M1009 are:
1. Install 1 ton axles from a truck variant. Then use the previously mentioned spacers. Or use a dually front end.
2. Have the HMMWV wheels recentered for the right backspacing and bolt pattern.
3. There are adapters out there to convert 6 lug to 8 lugs. But I wouldn't trust them.
4. Run aftermarket 6 lug 16.5" rims with HMMWV tires.
