Speedo Gear on Rear Transfercase PTO
jgusler
24134 Va
What kind of gauge hooks to the speedo gear that is located on the rear pto on a m35? I assume a rpm gauge but i've never seen one? I also did a search and tried to find the cable that would connect the two but couldn't find out nothing there either. Has anyone seen this gauge and cable?
1,827
No gauge, the cable is part of a speed governor used on fuel (and maybe water) trucks.
jgusler
24134 Va
Oh ok, thanks for the info. The PTO I bought was from and old gasser water truck so that explains a lot. Im going to remove it and just install a plug back in its place. Im having trouble with my PTO pulling oil from the transfer case and I think it might be drawing air around the speedo looking gear since I don't have a cable hooked to it.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
.............. Im having trouble with my PTO pulling oil from the transfer case and I think it might be drawing air around the speedo looking gear since I don't have a cable hooked to it.
That has nothing to do with the speedo and/or -cable disconnected.
Have you disassembled/ inspected/ cleaned both check valves? They may be stuck.
G.
m16ty
228
Dickson,TN
How do you tell if your pump is working? I've wondered if mine was working properly but never looked into how to check.
Another thing I've found out with these PTOs, one I pulled from a truck had a check valve in the elbow that screws into the bottom of the t-case. The one I pulled from another truck (which is on my deuce) just had a straight through elbow (no check valve). I would assume a check valve in that location would keep oil from draining back out of the line and keep the pump primed.
Does anybody else's truck have a check valve in the elbow?
jgusler
24134 Va
I used white plastic tube from tractor supply so that I could see if it is oil is being pumped thru the line. I didn't know that there was 2 check valves in it, I thought it just passed straight thru. I guess i will take it apart and inspect/clean these valves. Thanks for the info
