- 2,114
- 565
- 113
- Davis County, UT
The one that says "Viton" in the description, sorry it is buried in there and I could have made it more clear.So which part number was the Viton? I just cleaned my underside good so I need to see if this is my culprit. If so I'll order it. Do I need to drain the transfer case at when removing this? Or does it just come right out with no issue?
Thanks
Also, yes, came right out with no issue. I still need to check the fluid level in my transfer case, but unless I understand things wrong, the adapter is located higher than the transfer case fill point.2: A possibly slightly better match that I did not find in my online search (8x14x5VTC Double Lip Viton Oil Seal - he said this was metal with a rubber center - I'm thinking similar to one onegmjack got from his transmission shop, see here on page 1)
Item Number: 04545182
$4.29 each
https://www.motionindustries.com/motion3/jsp/mii/productCatalogSearch.jsp?q=04545182
