Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
I'll check mine, or check the TM (can't believe I'm saying that), but typically on anything with a low range, the pickup is then on the output of the transfer case. This way, the speed still shows correctly if operated in low or high range.
Modern automotive, yes, they simply take the average of the 4 ABS tone ring wheel pulses. Easy.
As Albert said. Speedometer is on the transfer case on the rear side of it. It has an adapter on it to make it offset. and the Tachometer goes to the engine.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
