LiveFreeOrDieTryn2B
- 20
- 18
- Springfield AR
I'm going to replace all the bearings gimpy got me covered for the gasket set.Do any of you see any damage in pics?
Tom was right... (but then never said a word?): there is (was) a mistake in that list and I'm very sorry for not discovering this any sooner...When I did mine, I sourced my bearings from the list and one didn't fit...tom told me there was something about a suffix in the number, but I can't find the conversation.
There really shouldn't be any play once the trans is installed. The pilot bushing(in the flywheel) should eliminate any play.I have the same issue with my truck that developed right before I went to sell it. Stupid truck
Front seal is leaking, causing clutch to slip.
Hey OP, Did you replace your disc?
M35tom, whats the tolerance allowed on front input shaft play? IE, how to determine if bearing is bad. That is my concern that bearing is bad, as that seems an unlikely seal to leak on its own.
ALso OP, How did you drop the trans?
