Spicer 5 speed question
MyothersanM1
19K M1 Armor Crewman
433
68
Culver City, CA
Okay, as promised, d/s lengths- front is roughly 61 3/4, and the one from the X-case to the forward rear axle is roughly 32 1/4.
I found this thread. It is your truck, correct?
https://www.steelsoldiers.com/showthread.php?172744-Transfer-case-upgrade-to-a-XM818
Would you be able to get some detailed photos of both the right and left frame and transfer case mountings. The thread only touched on unriveting and relocating the frame mounts. I am just curious as to which transfer case brackets were used.
simp5782
Feo, Fuerte y Formal
9,486
Mason, TN
Ajax MD
1,423
Mayo, MD
What is the advantage of retrofitting 809 series trucks with T1138 transfer cases? Is it a parts availability issue or is there some kind of performance improvement?
Edit: Nevermind, I found OPCOM's old thread a few doors down.
77 AMG
62
Owingsville, KY
Yep. That'd be me truck! Let me give some better light and I will be more than happy to take photos and measurements for you. I can tell you this, right up front- there are plates of steel in between the X-case and the brackets, AND you will have to either re-drill (yeah, not happening) the hole for the drivers' side step rear support, or just deal with it being tweaked out of the way of the forward mounting bolt.
