Spin on filter installation
dirtyfingernails
Gainesville, FL
I know this has been shown before, but not on my truck. I installed John's spin on filter kit this afternoon. Wow! what a breeze! While I had the filters off, I changed the two hoses for the oil cooler? They were splitting and I thought it was a good time. Anyway, the filter set up was a snap. Cleaned up the base, installed the gasket, installed the adaptor plate, torqued to 50 lbs, spun on the oil filters. Fired the truck up and nary a drop of oil. Thanks John! One last question. John, you don't find it necessary to use some type of locking fluid on the hex nipple? 50 lbs is sufficient? Thanks.
Steve
Jake0147
Panton, VT
I hate the way it looks. I'm pretty sure a quick spraybomb is going to fix that quite nicely. With all due caution and care of course, I'd hate to see paint under this or more importantly the next filter gasket. For now you can't see it with the hood shut. I like the way it works however. Fuel filters will be the same eventually, but for now myself and my checkbook have come to the consensus that I simply remove the science project from the first secondary and drive it as it is...
I'm very happy with the kit. The directions are quite clear. While I have not researched or reverse engineered the torque specs, the 50 pounds with no sealant or locking agent not only was not alarming, but was very much what I would have expected, and felt "good" to a well seasoned (but not infallable) "click elbow" just about the same time as the wrench clicked.
2cents
55Cameo
Gainesville, Fl
Hey Steve, I think you should have gotten 2 sets and come over and put one set onto mine. :lol: Looks good though. Are you going to do the same with the fuel filters?
sermis
17
Temple, TX
Re: RE: Spin on filter installation
FMJ said:
sermis said:
And I was almost ready to get some until I killed my lockout hub.
Hey how did your warranty replacement request work out?
No warranty, I knew that as it was not his fault. I sent the hub in. He said he could reuse the internals if they were ok and would knock some off the price.
jwaller
19
Columbia, SC
jatonka
send him a pm and he will hook you up. I have both the primary fuel filter conversion and the oil filter conversion. time to oil press is much better and so are the filters. I have piece of mind knowing the oil and fuel system are now much better filtered than ever before.
1,331
decatur alabama
wreckerman893 said:
Is there a contact number or addy for purchasing them?????
Hey come on over here and get you some. IF you ever keep a duece or engine long enough for one :lol: Im putting all the filter conversions on the winch truck and got the filters, and setups here for dueces if you want one.
