Spin on fuel filter mod
RedneckMilenko
Memphis/TN
My stock fuel filter housing is dumping out massive amounts of fuel so it's time to upgrade to a spin on filter. I've already pulled out the pressure sensor, tapped it, and pipe doped a screw to go in it but it turns out it's leaking from the back. I've already made a plan to use the NAPA 4770 base for my filter. My current problem is I'm not sure of what my flow rate is so I can choose the correct filter to go on it. Also, the wire harnesses that are going to the stock filter, do I need to do something with them or just tape them off and leave them hanging? I'm kind of in a rush to get this done being as my M1009 has turned into my daily driver and can't go to work till it's fixed. Thank you for any input.
1,174
Read the first two similar threads at the bottom of this page.
These should have come up with a search.
